Microphone amplifier
A project log for Dalek / Cybermen voice changer
A simple ring-modulator circuit which can change your voice to sound like a Dalek or Cybermen from Doctor Who
sproketSproket 11/05/2020 at 09:260 Comments
An electret microphone amplifier circuit using an LM386 has been successfully tested. With an additional capacitor between pins 1 & 8 for 200x gain, the amplified signal is a bit overkill. A potentiometer wired as a variable resistor will need to be included for setting the correct gain. This gain value could be fixed, but when using a microphone inconsistent input volume is to be expected.
Microphone amplifier schematic
Microphone amplifier on breadboard.
Using a speaker for output testing there is lots of feedback, especially when C4 200x gain capacitor is fitted.
Printed Circuit Boards.
This etched board shows version two of the layout with a corrected IC footprint and addition of component idents on the top copper layer. Components are on the bottom layer due to it being a single-sided PCB. Kicad can get confusing with idents being pushed to a different layer than the footprint, but it is workable.
First revision of PCB. Assembled and working.
