NOW I can start....
A project log for Low Voltage Pyroelectric X-ray Generator
Trying to develop an X-ray generator using a pyroelectric crystal, for less than 100$
razvan-caldararuRazvan Caldararu 10/07/2018 at 15:050 Comments
...I hope.
   So, the second vacuum pump, which is an Edwards E2M12, just had its maintenance and looks like it also works... kind of.
Before I explain, here's a few pics of the weekend-long overhaul process:
   There's a lot of rust gathered at the bottom of the gas ballast valce (where a ball bearing sits) and the ultimate vacuum I can reach right now is ~ 1 x 10e-2 mbar, which is pathetic. But at least it's enough for the X-ray experiment....just barely. I'll have to take the pump apart again and try to see if I can do something about that.
Alsom this has been a nightmare, from finding and getting the overhaul kit to getting the Pirani gauge. But at least the pump is back together and it works.
Next thing is to think about a small vacuum enclosure to put the crystal in and how to make some isolated feedthroughs for powering the TEC inside the vacuum chamber.
  This is gonna be fun :D
Will update things as they progress, of course. Oh, and I'll do  a separate thread about how I took apart the pump and changed some O-rings and seals.
