LoFive
Tiny RISC-V Microcontroller Board
Small breadboard friendly development board using the SiFive FE310 RISC-V Microcontroller.
Specifications
  • MCU – SiFive Freedom E310 (FE310) 32-bit RV32IMAC processor @ up to 320+ MHz (1.61 DMIPS/MHz)
  • Storage - 128-Mbit SPI flash (ISSI IS25LP128)
  • Expansion - 2x 14-pin headers with JTAG, GPIO, PWM, SPI, UART, 5V, 3.3V and GND
  • Misc - 1x reset button, 16 MHz crystal
  • Power Supply - 5V via pin 1 on header; Operating Voltage: 3.3 V and 1.8 V
  • Dimensions - 38 x 18 mm (estimated)
  • License - CERN Open Hardware Licence v1.2
  • 1 × FE310-G000 SiFive Freedom E310
  • 1 × IS25LP128-JBLE 128 Mbit SPI Flash
  • 1 × SPX3819M5-L-3-3 Power Management ICs / Linear Voltage Regulators and LDOs
  • 1 × SPX3819M5-L-1-8 Power Management ICs / Linear Voltage Regulators and LDOs
  • 1 × SN74LVC1G07 Logic ICs / Gates and Inverters
View all 13 components
View all 15 project logs
bb wrote 12/02/2019 at 13:47 point
After some googling I found the following guide explaining how you can use your J-Link with this board:
https://wiki.segger.com/GroupGets_LoFive_R1_1
I hope this is useful for some of you.
Gary Lee wrote 08/19/2019 at 09:46 point
Someone can tell me how to download the code into ?
Matheus Castello wrote 02/13/2019 at 14:46 point
Hello, I ported the Espruino, Javascript for microcontrollers, to the HiFive1 that uses the same MCU the FE310. Maybe it's interesting for LoFive. Check it out: https://github.com/microhobby/Espruino
David Reiss wrote 02/18/2018 at 04:41 point
It looks like the input to U5 (the SN74LVC1G07 buffer for JTAG_TRST_N is floating.  What prevents it from floating low and triggering a reset?  With the high input impedance of this chip, it seems like you could trigger this by just putting one finger on this pin and another on GND.
Michael Welling wrote 02/18/2018 at 04:45 point
Depends on what you are using to drive the JTAG. If you use the dual FTDI it works without a pull-up. But when I used the PocketBeagle to jam the JTAG, I had to pull the line up to 3.3V with an external resistor.
Michael Welling wrote 02/18/2018 at 04:56 point
Oh you mean when the JTAG is not connected. It is open drain.
David Reiss wrote 02/18/2018 at 07:42 point
The output is open drain, but what about the input of U5?  Can't that drift low, which would force the output low as well?
STEAL-THIS-HARDWARE wrote 08/29/2017 at 03:10 point
very awesome michael!!!! Is it easy to get samples of the chip?
Michael Welling wrote 08/29/2017 at 20:04 point
Not too bad. I just had to create the design and ask nicely.
A finished design helps.
Anders Dam Kofoed wrote 08/20/2017 at 16:39 point
Cool project. I have their first board.
Can we buy these fully assembled from you? If yes, what price?
Michael Welling wrote 08/20/2017 at 17:03 point
I haven't assembled any quite yet. That is coming up next week. I will post when/if they are available.
Stephen Newberry wrote 08/20/2017 at 01:51 point
Very nice. I really wanted to get a project going using this chip, so I emailed sifive at their listed email address to ask about availability. This was almost two months ago... still unanswered. Looking forward to seeing how this goes.
Michael Welling wrote 08/20/2017 at 17:12 point
I think that it is still a little early for public availability.
Stephen Newberry wrote 09/06/2017 at 01:00 point
Just an update - I did receive a reply from the company and they will be available soon on CrowdSupply. I didn't want anyone reading this to be misled - thanks for sharing your design!
arnaud.durand wrote 08/20/2017 at 00:32 point
Where do you source FE310 MCUs? I cannot find any supplier (if we omit desoldering from HiFive1).
Michael Welling wrote 08/20/2017 at 01:18 point
Engineering samples only for now.
