OrthoSense
OrthoSense is a wearable multi-sensory knee sleeve to monitor the progression of Osteoarthritis.
OSTEOARTHRITIS (OA) is one of the leading causes of disability and functional limitations in older adults. It is a multi-joint degenerative disease process which hinders the patient's movement. It is unfortunately accepted today as a common byproduct of ageing and the care provided is quite lacking. I was made aware of this when my mom had to undergo knee surgery and the rigorous rehab physiotherapy that followed. The short supply of trained physiotherapists coupled with the lack of feedback on the recovery inspired me to come up a solution which could help the users track the progress of their recovery post surgery.
OrthoSense is a connected knee brace sleeve which uses e-textile based sensors to measure the joint gait characteristics along with acoustic data. OrthoSense would also be helpful for even orthopedic doctors to get a deeper insight into their patients outside of their clinical settings. A smartphone based physiotherapy would feasible with this platform.
Problem:
• OSTEOARTHRITIS (OA) is often said to be a natural consequence of ageing and is one of the leading causes of disability and functional limitations in older adults
•The knee joint bears the full weight of the human body and the highest pressure loads while providing flexible movement, it is the body part most vulnerable and susceptible to osteoarthritis (OA)
• The growing number of cases is a heavy burden on the existing medical care system and the access to physiotherapist is quite difficult.
• While physiotherapists are able to work with the patient in their clinics and hospitals, They lack tools to supervise the patient's compliance to therapy and getting quantifiable data reflecting the performance.
• Long term real world gait would be essential to give the patient better care and can lead to better prevention and rehablitation
Background:
I, Vignesh am a final year engineering student from Chennai, India. I've always been into biomedical sensing and combining electronics and biomedical engineering.  Inspired after playing Deus Ex: Human Revolution as a 16 year old, My adolescent my mind was blown away by the possibilities in front of me. Reading about the work done by Dr.Hugh Herr at the Biomechatronics lab and Dr.Rosalind Packard at the Affective Computing lab MIT media lab. I realized I wanted to work on wearable sensors, After seeing the unbelievable progress in Machine Learning for the past few years empowering doctors with Machine Learning for diagnostics is my current goal. I have seen my mom suffer from Arthritis a year back and seen her struggle to do her physiotherapy exercise. One instance she over did the exercise causing a minor knee complication. I was thus inspired to work on a solution to help my mom and many other OA patients to get better care and lead a more comfortable life.
Solution:
OrthoSense- Wearable multisensory knee sleeve to monitor Osteoarthritis
                                            (Fig: Initial design of OrthoSense)
                                             (Fig: Prototype 1.0 layout)
Our solution is a sensor enabled knee sleeve made with comfortable and non obstrusive fabric sensor for gait measurement(joint angle) along with other essential parameters of the knee joint for both the physiotherapist and the patient to monitor progression of the their joint ailment. Our solution is a low cost (85$) method for the patient to acquire better care for OA.  The solution can either be purchased by the patient or be prescribed by the doctor in a rental model to out patients.
The patient wears the comfortable knee brace just as he is to start his daily physiotherapy exercise and pairs the device to his phone. After login, The custom rehabilitation exercise for the patient is loaded and friendly instruction animations guide the patient. A piezoresistive fabric sensor running through the knee joint measures the joint angle of the knee while the patient does the prescribed exercises. A 6DOF IMU records the joint motion data to give context to the other measurement. Finally, A tiny contact microphone picks up the acoustic emission of the knee bone giving insight on the nature of physical structure, soft tissue and most importantly the cartilage condition between the bone. This acoustic recording would provide cruicial information the patient's well being. The patient after exercise closes the session and continues on with their daily life still wearing the unobstrusive knee brace. The motion data and joint angle and acoustic are captured with the wearable during the patient's daily life when motion is present.
The data would be synced to cloud using the smartphone where classifiers would scrub through the data for valuable insights. The...
Waveform Audio File Format (WAV) - 4.25 MB - 09/05/2017 at 02:38
Download
  • 1 × tinyTILE - Intel® Curie Dev The tinyTILE, an Intel® Curie-based board, is a miniaturized adaptation Arduino/Genuino 101® board perfect for wearable and IoT applications. (https://www.sparkfun.com/products/14281)
  • 1 × Eeonyx LTT-SLPA-20K pressure sensitive stretchable fabric EeonTex Conductive Stretchable Fabric is a sensor coated with carbon and changes it's resistance depending on the pressure applied. It is used to measure the joint gait. (https://www.sparkfun.com/products/14112)
  • 1 × 3.7V 400mAh rechargable lithium polymer battery A miniature rechargeable battery to power the system.
  • 1 × BU-23173-000 Knowles contact microphone Piezo ceramic based contact microphone to monitor the joint cracks and clicks.
  • 1 × Adjustable neoprene breathable Knee Brace Knee Brace platform base for OrthoSense.
View all 6 components
  • CM-01B Contact Microphone
    Vignesh Ravichandran10/10/2017 at 10:24 0 comments
    While starting this project, I saw this sensor as a potential bottleneck due to my size constraints. Despite multiple failed experiments using a PVDF film (LDT0-028k) as it coupled to the knee using 3m adhesives, The signal was not too promising and the coupling method was a no go for a final prototype.
    I turned my sights back to the CM-01B sensor and wanted to figure out how on earth these guys pulled it off. I had gone through the publication the makers of this magic sensor had published  (Reference publication by MEAS spec
    Image result for cm-01b contact microphone
    The tech sheet had some interesting illustration which gives some critical insights about the working of this sensor, The film in this case is stressed and kept in curved form factor.
    While this was quite valuable to know I decided to get a more detailed insight by doing a bit of a teardown. Despite seeming to be rather simple an innocous, The device was rather difficult to teardown. I first tried using Allen keys to get the pins out to remove the sensing element from the enclosure but I was unable to get it to work.
    Then after spending hours I decided to go get the big tools out (My hand drill)
    I used the drill for on the four copper rivets to grind them out while holding it in a vice. Eventually they came off freeing the enclosure and the sensor module.
    "Not such a tough guy are you now" moment :D
    Inside the sensor we also find the transducer and circuitry to pick up the mechanical vibrations and contact sounds from the various sources.
    The setup consisted of a rubber extension which was coupled mechanically to a curved PVDF film held in place by a stiff holder. The film was also connected to preamp circuit which outputs amplified signal.
    Top view of the sensor.
    From the above we can infer how this device works and why it is quite accurate compared to simply coupling a PVDF film to the knee. Next I would need to design a custom version of this and try to make similar results work.
    Also, I think I need to give my hand a bit of rest after all that drilling.
  • Joint Sound processing
    Vignesh Ravichandran09/02/2017 at 09:35 3 comments
    Acoustical emissions have been used as a means to detect failures or damages in materials. It is often used in analyzing structures like bridges, flight wings and other vital structures. The bone itself consists mainly of collagen fibres and an inorganic bone mineral in the form of small crystals. In vivo bone (living bone in the body) contains between 10% and 20% water. Of its dry mass, approximately 60-70% is bone mineral. Doctors frequently use stethescopes to detect many ailments in lungs, heart and including bone damage.
    Vibroarthographic (VAG) signals emitted from the knee joint disorder provides an early diagnostic tool. Analysis of the knee sounds can provide a deeper insight into the condition of the joint bone condition along with the cartilage status between the knee. It can allow detection of complications and avoid inflammations at a later stage. During the active movements of the legs such as the flexion and extension, the vibration or auditory signals emits from the mid-patella section of the knee. Healthy cartilage is smooth and slippery producing minimum vibration while deteriorated cartilage is more irregular producing additional vibrations which can be audible in some cases. Vibrations generated by the friction of deteriorated articular surfaces are different in terms of frequency and amplitude compared to healthy ones, originating distinct VAG signals.
                          (Fig: VAG signals in healthy knee and arthritis knee, Feature extraction of VAG )
    High sensitivity contact microphones and directional electret microphones placed in the medial joint line can pick up the joint clicks and crackling sounds
                                                    (Fig: Position of the sensor)
    Osteoarthritic knees produce more frequent, higher peak, and longer duration acoustic emissions compared to healthy knees The contact microphone currently being evaluated in CM-01B PVDF contact mic and the Knowles BU-23842-000.
    I got the CM-01B contact mic for the starting test. I used the normal analogRead function on the teensy 3.2 at max speed to see what kinda data I was dealing with and I got this.
    The orange spikes mark the clicks as I moved my knee up.
    I hooked it up to the Teensy 3.2 due to the amazing audio library Paul has written. I set the filter bandwidth from 50Hz to 3000Hz at start to get some click sounds as I flex my knee. I attached the sensor to my knee with the help of the knee sleeve.  I configured the teensy to behave as a USB audio device (Amazing work Paul! Thanks!), Within no time I was able to connect it to audacity and I was able to record and play back the sounds.
    #include <Audio.h>
    #include <Wire.h>
    #include <SPI.h>
    #include <SerialFlash.h>
    // GUItool: begin automatically generated code
    AudioAnalyzeFFT1024    myFFT;
    AudioInputAnalog         adc1;           //xy=232.0161895751953,102.03934478759766
    AudioFilterStateVariable filter1;        //xy=381.01619720458984,139.0393409729004
    AudioFilterStateVariable filter2; //xy=510.0161819458008,127.26157188415527
    AudioOutputUSB           usb1;           //xy=657.0162696838379,105.03933811187744
    AudioConnection          patchCord1(adc1, 0, filter1, 0);
    AudioConnection          patchCord2(filter1, 0, filter2, 0);
    AudioConnection          patchCord3(filter2, 2, usb1, 0);
    AudioConnection          patchCord4(filter2, 2, usb1, 1);
    AudioConnection          patchCord5(filter2, 0, myFFT, 0);
    // GUItool: end automatically generated code
    void setup() {
      AudioMemory(12);
      filter1.frequency(2900);
      filter2.frequency(47);
      myFFT.windowFunction(AudioWindowHanning1024);
    void loop() {
      float n;
      int i;
      if (myFFT.available()) {
        // each time new FFT data is available
        // print it all to the Arduino Serial Monitor
        Serial.print("FFT: "...
  • IMU data visualization
    Vignesh Ravichandran09/02/2017 at 08:16 0 comments
    An inertial measurement unit (IMU) is an electronic device that measures and reports a body's specific force, angular rate, and sometimes the magnetic field surrounding the body, using a combination of accelerometers and gyroscopes, sometimes also magnetometers. They are commonly used in mordern UAV's, Smartphones.
    • Accelerometers respond to gravity as well as to their acceleration, and it can be used to estimate the inclination of a body segment, body sway, or for measuring activity levels, however accelerometers have some limitations such as noisy signals.
    • Sensitivity improved through the use of a gyroscope through sensor fusion which also provides information on the rotational characteristics.
    • In tandem they provide readings which can help determine context of the measurement (Walking vs Lifting foot, Running vs Climbing stairs vs Jumping)
    • The BMC150 6DOF IMU is used for the initial prototype but the next revisions would move to the BNO055 9DOF IMU to increase functionality.
    The Intel curie comes with the BMC150 IMU inbuilt which can help map the position of the knee. The recent capabilities have enabled the use of an IMU to determine the activity of the user to contextualize measurement.
    This would help find out if the person is walking, resting, running or climbing stairs. I loaded up a small sketch to test the accelerometer and gyro and I was stunned with the performance of the sensor.  The Curie IMU library enables an Arduino or Genuino 101 to read the output of the on-board IMU (Inertial Measurement Unit) containing an accelerometer and a gyroscope and elaborate the raw data coming from it.
    I tried doing some small activities and seeing the response and got this.
  • Joint Angle sensing
    Vignesh Ravichandran09/01/2017 at 02:28 0 comments
    Measuring human movements is important before rehabilitation, training or exercises can start. The knee was simply modeled as a hinge joint, and the flexion-extension angle was defined as the angle between the two consecutive joint segments. Existing methods include use of IR emmitter and motion capture cameras, pair of IMU's, electrogoniometers. They are quite expensive and implementation wise the dual IMU method would require wiring which could hinder gait. Our solution was to measure the joint angle using a piezoresisitive fabric sensor.
    Image result for joint angle                                 (Fig: Flexion extension angle.)
     A textile strain sensor was used on the wearable gesture sensing device to determine the resistance in response to the strain. The textile strain sensor consisted of the elastic piezoresistive fabric, two electrodes, two conductive textile wires.  Based on the relationship between the flexion angle and the resistance of the elastic sensor in the flexion-recovery cycles, the relationship between the flexion angle and the resistance of the textile strain sensor during the stretching and recovering movements can thus be obtained.
    The sensor is based off the Eeonyx SLPA 20kohm fabric cut to a 6cm length. It is then placed in the inside portion of a neoprene knee brace and put to stitch.
    (Fig: Positioning the fabric sensor in the knee brace)
    (Fig: Stitching the sensor to the knee brace)
    The sensor changes it's resistance as it expands or contracts. A wheatstone bridge network used to measure it accurately and 2.2uF capictor smooths it out.
    I quickly wrote up an analogRead code on the DFrobot curie to plot the values and lo and behold.
               (Fig: Raw sensor output while doing squats)
    Now to do the goniometer functionality, I needed to whip out my protractor to map the angle of the knee joint to to the analog values from the bridge network. This simple method results in the measurement of the joint angle accurately.
  • Idea Orgin
    Vignesh Ravichandran08/31/2017 at 05:43 0 comments
    This project is a bit close to my heart and I started this out as a way to help my mom who recently had a knee surgery. While the physiotherapy did help at start, She often needed close guidance from the therapist to aid her during rehabilitation. The therapist was rather hard to get hold often due to amount of patients he had to deal with for the same problem.
    I wanted to do something which could provide real assistance and insight into her joint condition in a easily understandable manner and also help the physiotherapist increase both his efficiency and standard of care in a home setting. I was suprised to find no solution to this problem in the market which consists of a wide spectrum of fitness monitoring wearables. I hope to fix that with this project and try to illustrate the untapped market of assistive wearable sensors for chronic care. The features I decided to include from start was joint angle monitoring, gait pattern sensing and the acoustic profile sensing of the knee.
    I conceptualized a home monitoring system which would allow the patient to track their progress with remote guidance from the physiotherapist. With less than 35% of the outpatients adhering to the training regimen suggested, It is important to have a reinforcement system to evaluate patient compliance and provide them motivation to continue.
    Here's a sketch of the initial concept I came up with.
View all 5 project logs
R3dmous3 wrote 09/28/2017 at 21:18 point
Depending on how much data you can collect you may even be able diagnose issues with joints before they become a problem.
