Changing the looks
A project log for Utterly Hipster Bicycle Speed & Cadence Gauges
Two analog voltage meters, ATtiny85s and some parts from a modern bike computer turned into speed and cadence gauges for a hipster's bicycle
insight-machines-labInsight Machines Lab 08/28/2017 at 21:340 Comments
Tried to remove the plastic ring around the gauge today. Without a proper stand for a drill to cut a perfect circle with the diameter of 65mm, we opted for a more brute-force approach with the Proxxon Micromot 230 and a routing bit.
The result wasn't perfect...
... But it has to do.
