control
A project log for longboardLight1
LED longboard light setup
matt-thurstanmatt thurstan 08/07/2021 at 22:290 Comments
Hardware:
Software:
Currently:
  1. If the WIFI is on the microcontroller runs a local Access Point.
  2. A mobile device connects to the AP.
  3. Using a browser to go to a webpage for controls and settings.
TODO:
  1. First startup (or full reset) - run WIFI AP with such options as save current device and connect to home network.
  2. Second startup - scan for saved devices/networks.
    1. if home network found
      1. then connect.
    2. if mobile device found and no home network found
      1. then run WIFI AP.
      2. [ user connects mobile device to AP. ]
