​MkIII: Aluminum Ring
A project log for Silent Orchestra POV aka "Death Ring"
a wicked large interactive POV display for festivals and stuff
booleanboolean 08/21/2014 at 17:440 Comments
A whole new design with drivetrain was drawn up in Solidworks and created at Makerplace and FablabSD (it's current home).
This new version adds:
a lightweight aircraft grade aluminum ring
CNC machined drive train
3HP AmpFlow brushed motor
Kelley controller with 0-5v sense for power
2x750 watt drive PSUs ( from robotics)
RPM control via Arduino, hall effect sensors and an R/C pass 0-5 Speed controller signal
physical positioning via a MPU-6050 ( for low RPM POV)
serial bluetooth position sending to processing
Drivetrain with Idler installed
Plasma'ed piece on ring assembly
Welder with the finished Al ring!
Rotating Electronics
Communications Diagram
Electronics Schematics
