close-circle
Push rod top, done.
A project log for Arcus-3D-C1 - Cable 3D printer
3D printable, Open Source Hardware, tripod kinematics, cable driven 3D printer
Daren Schwenke 10/17/2017 at 02:320 Comments
Mocked up a simple clamp and wingnut for adjusting the compression spring on the push-rod.
Uses a regular M3 nut, bolt, and washer.
Printed.  Works.
Added to the OpenSCAD source.
EDIT: Broke it.  Changed the design to make it stronger in that area.
