close-circle
Arduino Sketch
A project log for Mixed Reality Room Scale Shooting Gallery
A mixed reality shooting gallery for room scale tracked mobile devices.
Richard Hogben 08/23/2017 at 15:183 Comments
Modified from James Bruton's sketch example. This sketch uses the serial connection to listen for servo addresses 100 through 115, then activate, pause, and return each servo called.
The Unreal Engine app only has to send the address followed by a newline.
This first sketch had a couple for loops that were too slow:
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
#define SERVOMIN  150 // this is the 'minimum' pulse length count (out of 4096)
#define SERVOMAX  600 // this is the 'maximum' pulse length count (out of 4096)
int action;
long interval = 500;
unsigned long currentMillis;
long previousMillis;
uint8_t servoAddr[] =       {  0,  1,  2,  3,
                               4,  5,  6,  7,
                               8,  9, 10, 11,
                              12, 13, 14, 15  };
int flagAddr[] =            {  0,  0,  0,  0,
                               0,  0,  0,  0,
                               0,  0,  0,  0,
                               0,  0,  0,  0  };
long previousMillisAddr[] = {  0,  0,  0,  0,
                               0,  0,  0,  0,
                               0,  0,  0,  0,
                               0,  0,  0,  0  };
void setup() {
  Serial.begin(9600);
  pwm.begin();
  pwm.setPWMFreq(60);
void run_servo(uint8_t &myServo, int &myFlag, long &myPreviousMillis) {
  if (myFlag == 1) {
    // pwm.setPWM(myServo, SERVOMIN, SERVOMAX);
    for (uint16_t pulselen = SERVOMIN; pulselen < SERVOMAX; pulselen++) {
      pwm.setPWM(myServo, 0, pulselen);
    myFlag = 2;
    myPreviousMillis = currentMillis;
  } else if (myFlag == 2 && currentMillis - myPreviousMillis > interval) {
    // pwm.setPWM(myServo, SERVOMAX, SERVOMIN);
    for (uint16_t pulselen = SERVOMAX; pulselen > SERVOMIN; pulselen--) {
    myFlag = 0;
void loop() {
  currentMillis = millis();
  if(currentMillis - previousMillis > interval) {
    previousMillis = currentMillis;
    if (Serial.available() > 0) {
      action = Serial.parseInt();
      if (Serial.read() == '\n') {
        for(uint8_t i = 0; i < 16; i++) {
          if (action == (100 + i)) {
            flagAddr[i] = 1;
        run_servo(servoAddr[i], flagAddr[i], previousMillisAddr[i]);
Current sketch with the for loops unwound:
#include <Wire.h>
int action;
long interval = 2000;
                               4,  5,  6,  7,
                               8,  9, 10, 11,
                              12, 13, 14, 15  };
                               0,  0,  0,  0,
                               0,  0,  0,  0,
                               0,  0,  0,  0  };
                               0,  0,  0,  0,
                               0,  0,  0,  0,
                               0,  0,  0,  0  };
void setup() {
  Serial.begin(9600);
  pwm.begin();
  pwm.setPWMFreq(60);
  if (myFlag == 1) {
    myFlag = 2;
    myFlag = 0;
void loop() {
        if (action == (100)) {
          flagAddr[0] = 1;
        if (action == (101)) {
          flagAddr[1] = 1;
        if (action == (102)) {
          flagAddr[2] = 1;
        if (action == (103)) {
          flagAddr[3] = 1;
        if (action == (104)) {
          flagAddr[4] = 1;
        if (action == (105)) {
          flagAddr[5] = 1;
        if (action == (106)) {
          flagAddr[6] = 1;
        if (action == (107)) {
          flagAddr[7] = 1;
        if (action == (108)) {
          flagAddr[8] = 1;
        if (action == (109)) {
          flagAddr[9] = 1;
        if (action == (110)) {
          flagAddr[10] = 1;
        if (action == (111)) {
          flagAddr[11] = 1;
        if (action == (112)) {
          flagAddr[12] = 1;
        if (action == (113)) {
          flagAddr[13] = 1;
        if (action == (114)) {
          flagAddr[14] = 1;
        if (action == (115)) {
          flagAddr[15] = 1;
    run_servo(servoAddr[0], flagAddr[0], previousMillisAddr[0]);
    run_servo(servoAddr[1], flagAddr[1], previousMillisAddr[1]);
    run_servo(servoAddr[2], flagAddr[2], previousMillisAddr[2]);
    run_servo(servoAddr[3], flagAddr[3], previousMillisAddr[3]);
    run_servo(servoAddr[4], flagAddr[4], previousMillisAddr[4]);
    run_servo(servoAddr[5], flagAddr[5], previousMillisAddr[5]);
    run_servo(servoAddr[6], flagAddr[6], previousMillisAddr[6]);
    run_servo(servoAddr[7], flagAddr[7], previousMillisAddr[7]);
    run_servo(servoAddr[8], flagAddr[8], previousMillisAddr[8]);
    run_servo(servoAddr[9], flagAddr[9], previousMillisAddr[9]);
    run_servo(servoAddr[10], flagAddr[10], previousMillisAddr[10]);
    run_servo(servoAddr[11], flagAddr[11], previousMillisAddr[11]);
    run_servo(servoAddr[12], flagAddr[12], previousMillisAddr[12]);
    run_servo(servoAddr[13], flagAddr[13], previousMillisAddr[13]);
    run_servo(servoAddr[14], flagAddr[14], previousMillisAddr[14]);
    run_servo(servoAddr[15], flagAddr[15], previousMillisAddr[15]);
kavyachandrashekar16 wrote 08/24/2017 at 16:06 point
sorry I'm new on this i want to know that, for what it is???
cyberhacker wrote 08/23/2017 at 19:01 point
sorry sir but i m new on this and i want to know that ,what is this and, how & for what this works?
Richard Hogben wrote 08/23/2017 at 20:25 point
This is an Arduino sketch to control a set of servos.
