Rehab Helper is assembled and hand plate installed
A project log for Post Stroke Spasticity Rehab Helper
The spasticity is the most common post stroke effect. We construct simple open sourse Arduino -based Post Stroke Spasticity Rehab Helper.
sergei-v-bogdanovSergei V. Bogdanov 09/02/2017 at 21:580 Comments
We use one more breadboard to make hand plate, so You can lay hand for massage.
And the final test is over- all work fine.
