Here I will document my learning curve. The number of correct interpretations of the patterns are tracked and I will regularly update the plot below.
I practices a little bit less than I had hoped, but even with so few trials I am happy with the improvement. It must be said that each trial lasted about 10 minutes and had on average just 20 different patterns.
