45W RF SSB CW AMP (EBAY) DIY Build = 55W Upgrade
Back to overview
This is a guide to build & improve this $14 DIY Ebay kit as the OEM docs (also incl. here) are borderline Chinglish.
bcmoore wrote 08/27/2022 at 18:51 point
Hi, I just got this amp kit and would like to do your modifications. Can you tell me a source for the thermistors?  I have V3.06 of this amp. It appears to differ from yours in that T1 has separate primary and secondary windings. It looks like you have a version 3.08. Can you post the schematic of your version? Also how can you implement a 3:7 winding for T3, if the primary has 3 turns? It seems the center tap would be at 1.5 turns, on the wrong side of the coil. Thanks
Regards, Brian KA1FT
garello wrote 10/01/2017 at 19:42 point
Could you possibly post the LT spice file?
Andy, KM4TRT
garello wrote 10/01/2017 at 19:26 point
Looks like a complete and lucid hack discription.  i ordered one and intend to do your mods. I didn't read where you used the amp or what you used it on.
My bitx 20 has 2 IRF510s for output for about 8-10 watts.  Would I better off taking power from the stage before output, rather than trying to turn down to such a small output? Or is there another way (attenuater of some sort?)
Thanks
Andy KM4TRT
