PCBs Arrived
A project log for FAIO - Feather All-in-One Switch
What if you could have a universal switch interface that could support different types of switches all-in-one device?
miladMilad 09/20/2017 at 04:370 Comments
I received the PCBs in mail last week and they look great as you can see below:
The first board is the main board with 2 3.5mm jack connectors,3 Grove connectors,and pressure sensor for Sip-and-Puff switch.
The second board is the braille module which will be connected to main board through 3 Grove connectors.
