Credit's due
A project log for heg4all
Fix or improve your brain with the simplest and least intrusive technique currently available, hemoencephalography, DIY style
allstargajoallstargajo 09/02/2017 at 23:000 Comments
I've struggled quite a bit before creating this project. Ever since I learned about Hackaday Prize I waited patiently for someone to submit something similar so I wouldn't be tempted to submit this myself.
You see, this endeavor is not mine to claim. In 2016, on another forum, someone proposed to create a low-cost HEG system and then someone else follow through. The nature of the forum has barely anything do to with hardware so it's not a surprise that this contest might have gone unnoticed. But now the deadline for what seems to be the last chance this project has of getting some deserved attention is imminent and I cannot let it pass by.
I believe neither users would be against this, so I decided to publish the project and submit it to Hackaday Prize but not without acknowledging them rightly first.
