PortaCadenaaRectificado.SLDPRT
The chain goes stored in here
sldprt - 298.98 kB - 08/31/2017 at 02:23
Download
CadenaMasGrandeRectificado.SLDPRT
This is the chain, you should print 13 of them
sldprt - 69.15 kB - 08/31/2017 at 02:23
Download
TapaPortaCadenaRectificado.SLDPRT
Cover of the chain storage part
sldprt - 105.80 kB - 08/31/2017 at 02:23
Download
FijadorPortaCadenaRectificado.SLDPRT
Part to fix the chain storage
sldprt - 89.89 kB - 08/31/2017 at 02:23
Download
sldprt - 232.63 kB - 08/31/2017 at 02:23
Download
sldprt - 167.60 kB - 08/31/2017 at 02:23
Download
sldprt - 139.12 kB - 08/31/2017 at 02:23
Download
SostieneDestornillador.SLDPRT
A part I made to hold a screwdriver I took from an actual multi-tool so I'd have metal tools instead of plastic printed ones
sldprt - 121.41 kB - 08/31/2017 at 02:23
Download
sldasm - 604.46 kB - 08/31/2017 at 02:23
Download
sldprt - 232.30 kB - 08/31/2017 at 02:23
Download
NewChainRammerGearRectificado.SLDPRT
Gear that pushes the chain out and retracts it
sldprt - 403.14 kB - 08/31/2017 at 02:23
Download
FinalDeCarrera.SLDPRT
Model of the limit switch used
sldprt - 91.68 kB - 08/31/2017 at 02:23
Download
Engranaje2Rectificado.SLDPRT
Gear that goes attached to the servo which moves the tool holders
sldprt - 154.72 kB - 08/31/2017 at 02:23
Download
BotoneraRectificado.SLDPRT
Just a part to put the controlls(unfinished)
sldprt - 54.77 kB - 08/31/2017 at 02:23
Download
Engranaje2XLRectificado.SLDPRT
Other gear used to move the tool holders
sldprt - 150.59 kB - 08/31/2017 at 02:23
Download
ArduinoEsquemaRectificado.SLDPRT
Arduino UNO sketch. Feel free to use it for other purposes!
sldprt - 58.32 kB - 08/31/2017 at 02:23
Download
Servo SG90Rectificado.SLDPRT
SG90 servo I downloaded from thingiverse years ago, credit to the one who made it!
sldprt - 262.34 kB - 08/31/2017 at 02:23
Download
SostieneEjesParte2Rectificado.SLDPRT
Separator to avoid the tool holders colliding with the gears
sldprt - 110.02 kB - 08/31/2017 at 02:23
Download
SostieneEjes2SuavizadoRectificado.SLDPRT
Part where the axes sit and the servos are fixed to
sldprt - 301.99 kB - 08/31/2017 at 02:23
Download
PortaPortaherramientasRectificada.SLDPRT
Tool holders. Designed to mathematically minimize the space used (yes, really)
sldprt - 266.33 kB - 08/31/2017 at 02:23
Download
