Player Arm
A project log for Custom Record Player
Reworking a low-end record player into a classy design.
zachZach 09/11/2017 at 20:590 Comments
I've designed and printed the arm, which is most complicated piece. If fits snaps into the raised arm nicely, rotates well, and fits the needle.
The clasp that holds in the needle is a little brittle and might not stand up to swapping out the needle. Something to consider updating in future revs.
