Multi-Slave Write Access Demo
A project log for InterNoC
A Network-on-Chip for the System-of-Systems Era Enabling mixed interface communication between embedded devices (MCU, sensors etc.)
lefteris-kyriakakisLefteris Kyriakakis 12/12/2017 at 13:320 Comments
After a few weeks of days of debugging and a few weeks of life getting in the way a first real-case scenario demo of the InterNoC functionality is presented here...
Setup
This log presents a demo of the InterNoC hardware design (see Fig. 1) implemented on a CMOD Artix-7 development board.
Simplified InterNoC Demo Hardware RTL
Fig. 1 Simplified InterNoC demo hardware RTL
In the demo, a master device (STM32 dev. board) is programmed to perform write accesses of different byte count through a UART interface. Two devices were connected to the InterNoC and acted as SPI slave devices:
  1. An STM32 dev. board
  2. An oscilloscope with interface decoding capabilities
These devices were chosen in order to facilitate the verification of the InterNoC correct operation. Furthermore, as a means of in-circuit verification the Xilinx Integrated Logic Analyzer (ILA) was used.
The following was defined in-order to communicate using the InterNoC using two mockup messages "ok" and "test" sent respectively to slave 1 and slave 2:
#define INTERNOC_WRITE_CMD 0x0
#define INTERNOC_READ_CMD 0x1
#define INTERNOC_SLV_0 0x0
#define INTERNOC_SLV_1 0x1
// bytecount | access type | slave address in InterNoC
#define INTERNOC_CONSTRUCT_HEAD(byteCount, cmd, addr) ((byteCount << 5) | (cmd << 4) | (addr))
uint8_t write_addr_0 = (uint8_t) INTERNOC_CONSTRUCT_HEAD(0x2, INTERNOC_WRITE_CMD, INTERNOC_SLV_0);
uint8_t write_addr_1 = (uint8_t) INTERNOC_CONSTRUCT_HEAD(0x3, INTERNOC_WRITE_CMD, INTERNOC_SLV_0);
char buffToSend[2] = "ok"; // TX buffer for slave 1
char buffToSend1[5] = "test"; // TX buffer for slave 2
Demo
The master STM32 dev. board was programmed to perform the following loop:
The oscilloscope received correctly the transmitted 4 bytes as presented in the scope capture (see Fig. 2):
Slave 2 scope decoder receives message correctly
Fig. 2 Slave 2 scope decoder receives message correctly
Following up is a video of the presented setup running the demo:
