Simulations
A project log for Ping#
Beam-formed ultrasonic distance sensor
jlamJLAM 09/21/2017 at 16:540 Comments
Using octave and a modified example from Julius Piso I got the following output. It does correlate well with the beam pattern from the real device with the 3 lobes. next step will be to extract the beam pattern from the simulation and plot it alongside the measured beam pattern.
