I am entering one of the two components of this planned project into an IoT contest over on Hackster.io.
This contest entry focuses on the IoT Control Unit, which is ESP8266 driven so meets the criteria for the contest.
The Pi-powered Hub Unit will be documented over there for future contest use.
Soon I will be adding more documentation to the project here on Hackaday.io following some more work on the code; I'm happy with the builds using enclosures by the magnificent @Hartmut Wendt and am now currently focusing on integrating MQTT to have my network function as intended.
Peace out!
https://www.hackster.io/CraigHissett/dinternet-iot-controller-34d00f
Craig Hissett
