Weekend long design and build time!
A project log for 'If you can't reach your toes' nail clipper
A toe nail clipping station to support your foot, position a pair of heavy duty nail clippers and cut your nails without bending over.
riley-boothRiley Booth • 09/03/2017 at 18:30•0 Comments
Last weekend (Aug 25th - 27th) we built our first prototype of our new design.
The project materials were pretty simple:
Sheet plywood, 4' of 1/4" thick aluminum rod, 1' of 1" diameter 1/8" thick aluminum tube, 1/3' of 1/2" diameter wooden dowel, hockey tape, a pair of nail clippers, a shaving mirror, some nails, glue, pipe clamps, nuts and bolts, and fishing line.
We used wood working power tools to cut the base, drills holes in it, and jigsaw the slots in it. Then we nailed/glue it together.
The nail clipper holder had couple machining tasks. The 1/2" thick was was cut in half, and two holes were drilled in it. The tube was cut in half as well, a 1/2" diameter hole drilled though it and a slot cut down the length. The rod was bolted to the side of  the base, the tube slid down the rod and could clamp the nail clippers using the pipe clamp. By wrapping the top handle of the nail clippers in hockey tape, we made it round and fit snugly in the tube, and when it was clamped, it wasn't going anywhere.
The shaving mirror just needed  a hole in the side of the base to be slotted in.
The last touch was to weave about 9 threads of fishing line into a thick and sturdy rope, which was attached to the bottom of the nail clippers on one end, and knotted through a hold in the wooden dowel on the other end. This made a nice sturdy handle to pull for making the clippers clip!
