Customizable motorcasing
A project log for HaptiVision
A haptic vest for orientation for the blind
rene-niewiandaRene Niewianda 09/05/2017 at 15:400 Comments
In order to use different sizes of rumble motors a new casing type was added. This one is now fully customizeable, it fits almost for every motor. Other customizeable parameters beside the dimensions of the motors are for example the depth of the walls or an offset so thicker fabtic can be used. All options that can be changed are commented in the scad-file, in order to explain what they will change.
The scad-file also contains a test-method to check if everthing was scaled correctly, because in the case that the motor ist very large the clippers might be to thin to keep it in place.
