Antenna orientation
A project log for Samsung NP540U4E to BLE keyboard conversion
I always wanted to have a wireless keyboard with touchpad. Preferably with Bluetooth. So I have started to build one.
miklos-martonMiklos Marton 09/16/2017 at 08:240 Comments
After routing the initial layout I have came across some antenna design related material namely the AN91445 from the Cypress. Section 7.1 covers the YJ-14015 antenna type (MIFA == Meander Inverted-F Antenna).
By seeing this radiation pattern:
The current orientation is not the best (most likely the keyboard is going to be used in front of the receiever).
It's time to update the design.
