Planetary Gripper
A project log for Three-Jaw Grip-Stick
Off-the-shelf pickup sticks only work if the person has the grip strength needed. This is a servo-driven, three-jawed alternative.
darkredhorsedarkredhorse 09/11/2017 at 23:230 Comments
The very early inspiration for the current version of the gripper came in three pieces:
1) The ring gear and the planet carriers could be outfitted with fingers
2)The planet gears themselves could be the drivers for the fingers
3) From a previous two-jawed gripper, the strange triangular, pivoting-about-their-centre "fingers" could conform to different shapes by pivoting like windshield wipers do to conform to a windshield
The result is odd-looking, but can pickup virtually any shape, a wide range of sized objects, and grips from outside or inside a larger hollow object as needed.
