CIS or CCD ?
A project log for Magic Frame : Turn Everything into a Touch Area
Build your own touch screen solution adapted on your TV by using some CIS or CCD sensors from old scanners
jean.perardeljean.perardel 10/04/2017 at 14:430 Comments
There are two types of sensor in a scanner. The one I mainly used is actually a CIS (Contact Imaging Sensor) and not a CCD (Charged Coupled Device). You can either, but CCDs are really small. To cover a large screen, it's easier to use a CIS.
I've actually mistaken CCD and CIS on the video, I will change it soon...
I ordered several CIS sensors from "ON SEMICONDUCTOR" on Ebay :
-> The CE841-60111 which has 1728 sensors on 232mm
-> The CB376-67901 which has 2048 sensors on 272mm
If they work well, it's going to be a good start for building a screen frame.
This website is really insterresting in helping you  understand the differences.
