Magic Frame V2 printed and wall mounted
A project log for Magic Frame : Turn Everything into a Touch Area
Build your own touch screen solution adapted on your TV by using some CIS or CCD sensors from old scanners
jeanperardeljean.perardel 10/16/2017 at 18:500 Comments
A lot of printing hours later....
Here are 2 of my LED frame elements plugged in. I added the IR LED and the driving circuit.
I only added 1 LED per line (except on the seventh one, there are 3) because it's enough for the first frame size I want to build.
I also drew a roof for the element to hide the wires and circuit.
And now, the frame complete. There are actually only 4 elements at the top and bottom, but they are a bit larger.
We can see the round rotary button under the word frame. You can increase or reduce the CIS's sensitivity with it.
I am really sorry... This assembly is a mess!
That's one of the reasons why I've I immediately started to drawing a Magic Frame V3   :-p
