Why I Hate Analog Circuits
A project log for Trinket Shields
Add-on boards for the Adafruit Trinket M0.
de∫hipude∫hipu 10/10/2017 at 17:406 Comments
I'm completely hopeless with analog circuits. I think part of it might actually be a self-fulfilling prophecy — I know that I'm bad at it, so I'm not even trying. Usually I just try and copy any analog pieces I need from other projects, cargo-culting them and hoping they will work. A case in point: the audio shield.
Simplicity itself. A small audio amplifier, connected through a resistor and capacitor to the DAC pin on one side, and to an SMD speaker on the other. What could possibly go wrong?
First of all, I re-used a footprint for the PAM8301 amplifier, using a part for some sparkfun's DAC chip. It's exactly the same size, I just changed the labels on the pins. What I failed to note is that the pins on that chip are numbered in the opposite direction than on my amplifier. So to start with, I had to bend the pins of the chip the other way and dead-bug it. Fine.
Next thing I am a little less sure of. I mean, I am sure it doesn't work, but I'm not sure why. If I connect a piezo to the DAC pin directly, I get the sound that I'm playing (although very quietly). If I use the amplifier (with a 47kΩ resistor and 0.1µF capacitor between the pin and the input of the amp), I get nothing. And it gets warm. Sounds like it's simply connected wrong, but I verified the PCB and the datasheet a million times already.
I must be missing something obvious, here's the schematic so that you can laugh at my ignorance:
Oh, and yes, I copied it. From Adafruit's Circuit Playground Express board, which also uses a SAMD21 chip and a very similiar SMD speaker.
arturo182 wrote 06/13/2019 at 19:47 point
Hey @deshipu did you ever figure out what was the problem, I'm testing my design (https://hackaday.io/project/165887-pam8301-breakout-board) with a SAMD51 board and while I can sometimes get some sound (mostly when i touch the wires in the "correct" way, it's pretty bad overall. I do wonder if audio just hates jumper wires and it will work better when it's on the same PCB as the MCU, or is there some extra design considerations?
de∫hipu wrote 06/13/2019 at 20:27 point
Faulty chips in my case.
arturo182 wrote 06/13/2019 at 20:57 point
Oh, so just putting a new one worked fine? I got mine from Mouser so I guess it should be fine. Maybe it's the wires after all.
de∫hipu wrote 06/13/2019 at 21:08 point
Yeah, check the next log entry.
Clara Hobbs wrote 10/10/2017 at 20:25 point
I don't see your schematic's R7 in the PAM8301 datasheet's typical application circuit.  Out of curiosity, what would happen if you made that 0 Ω instead of 47 kΩ?
de∫hipu wrote 10/10/2017 at 20:56 point
Tried that, no change. I now suspect the chips (which I got from Aliexpres) are faulty. Ordered (hopefully) good ones from Mouser, we will see when they arrive.
