The main structure of the robot is a 5' tall plastic skeleton cut down to 4' tall. The robot has 9 servos. 6 servos operate the left and right shoulders elbows and wrist. One servo runs his mouth, one turns his head and one moves his right ankle . There are RGB led lights in his eye sockets and small dc motor with a counter weight which makes the robot shake. I used Visuino Software to program the robot
I really appreciate the solid mechanical design you are doing there — all servos using push rods and separate bearings and everything. I've been guilty of abusing servos as hinges myself so many times, it's nice to see it done properly.
Thank you I hope to get back to Boney the Skeleton Dog. Check him out.
