The MAD IN lite is a fully differential stereo line receiverto single ended converter with two 1/4" TRS input jacks, with independent volume control, reference level setting (-10dBV or +4dbU) and support for external preamp modules with differential outputs, hosting THAT Corp and TI audio line of opamps; the module offers a screw terminal block for easy and reliable connection to the power supply
