Fork of project Nyan Board ( <a target="_blank" rel="noopener noreferrer" href="https://hackaday.io/project/7860-nyan-board">https://hackaday.io/project/7860-nyan-board</a> ) for EarringsThis version include Kicad file welcome collaborations! with two version:<br><a target="_blank" rel="noopener noreferrer" href="http://gerber.zip">gerber.zip</a> - single nyancat <br><a target="_blank" rel="noopener noreferrer" href="http://PCBPanel.zip">PCBPanel.zip</a> - Panelized<br><br>This is just a purely for fun project, that is supposed to get me into programming those small ATtiny chips. I got this idea when I looked at the ribbon cable of my programmer -- it's a rainbow! The board doesn't do much, just blink the cat's eyes and play the tune on a buzzer.<br><br>TODO:<br>- Test Supercapacitor<br>- Test CircuitThanks <br><br>Radomir Dopieralski
It looks like the SVG import didn't work quite right — all the curves are converted to straight lines. Have you considered using Fritzing for this? It's not good for super-huge complex projects, but for small artsy things like this it is perfect, and since it uses SVG for everything internally, importing it works very well.
