close-circle
NyanCatEarrings
Fork of the project Nyan Board for make earrings
close
Fork of project Nyan Board ( https://hackaday.io/project/7860-nyan-board ) for Earrings
This version include Kicad file welcome collaborations! with two version:
gerber.zip - single nyancat PCB
Panel.zip - Panelized
This is just a purely for fun project, that is supposed to get me into programming those small ATtiny chips. I got this idea when I looked at the ribbon cable of my programmer -- it's a rainbow!
The board doesn't do much, just blink the cat's eyes and play the tune on a buzzer.
TODO:
- Test Supercapacitor
- Test Circuit
Thanks Radomir Dopieralski
panel.zip
Gerbers version panel
Zip Archive - 1.01 MB - 09/10/2017 at 19:14
download-circle
Download
Radomir Dopieralski wrote 09/12/2017 at 16:24 point
It looks like the SVG import didn't work quite right — all the curves are converted to straight lines. Have you considered using Fritzing for this? It's not good for super-huge complex projects, but for small artsy things like this it is perfect, and since it uses SVG for everything internally, importing it works very well.
Arsenijs wrote 09/13/2017 at 22:06 point
Alternatively, I made a tutorial on importing vector outlines into KiCad properly: https://hackaday.io/project/7431-the-kicad-central/log/50436-importing-board-outlines-tips-and-tricks
