Log #4 - It mills
A project log for RPM9001 - Rapid Prototyping Machine
CNC machine with swapable tool heads for rapid prototyping, built as inexpensive as possible.
Raphael SchaafRaphael Schaaf 10/02/2017 at 07:310 Comments
Just a quick update, I did a small test with the milling head this weekend.
RPM9001 with the milling head mounted
Sadly I only had the time to do a quick test with styrofoam, because I had to reprint a part that took 11 hours.
This is the result of the test:
The cuts look pretty good and the mill ran very quiet, I hope it works as well with wood and other materials...
