Just a quick update, I did a small test with the milling head this weekend.
Sadly I only had the time to do a quick test with styrofoam, because I had to reprint a part that took 11 hours.
This is the result of the test:
The cuts look pretty good and the mill ran very quiet, I hope it works as well with wood and other materials...
