Why are you using a shitty microphone?
A project log for Good sound from bad
Lets use machine learning to make a bad speaker make good sound.
oliverOliver 08/20/2014 at 20:551 Comment
So lots of people have asked me this...
It turns out in my diagram in the previous update that the microphone quality doesn't matter.   Here's why:
I play a sound x through the good speaker (G), record it with the shitty microphone (M).  I then do the same with the modified sound y and bad speaker (B), and analyse the difference.
Turns out I'm analysing:
M(G(x)) - M(B(y))
And since M is present in both terms, the eventual result after many repeats will be:
M(G(x)) ~= M(B(y))
G(x) ~= B(y)
So the microphone got cancelled out!   (Note this is only strictly true if function M is invertible, but we'll assume it approximately is...)
PointyOintment wrote 08/20/2014 at 21:26 point
As long as the microphone isn't 100% bad (i.e. completely non-functional)!
