What can it run ?
A project log for YGREC8
A byte-wide stripped-down version of the YGREC16 architecture
yann-guidon-ygdesYann Guidon / YGDES 08/16/2018 at 12:340 Comments
#YGREC-РЭС15-bis has 16 bits wide registers that make it suitable for quite a few things, including running Tetris and Game of Life. However, the #YGREC8 is only 8 bits wide and this limits the range of programs even more. I'll focus only on "toy games" because they are the most attractive applications, while I also consider other uses such as PLC or monitoring.
Tetris is still somewhat possible but it would be an impractical stretch because the 10 columns exceed the 8 bits of the registers, and the processor is too slow to animate that smoothly : the display would be sheared.
Tic-tac-toe is a contender.
Battleship is another good candidate : it's not a hard real-time game and animations are not critical. However I would have to build 2 units and make them communicate somehow... So it would be good to develop communication protocols, later.
Another good challenge is the SNAKE game. It doesn't require too much computing power and could run fast enough to be enjoyable. The problem is to memorise a linked list of coordinates, which could exceed the DRAM capacity... But there is a not-too-hard solution :-)
It requires 4 bitplanes :
so overall, there are 4 bits per pixel. With a 16×16 pixels array, that's 128 byte of DRAM, or half the addressing space of one address register.
It shouldn't be too hard, right ?...
I have a 16×24 flip dots array that leaves 16×8 pixels to display the stats of the game.
