ASM panel dimensions
A project log for YGREC8
A byte-wide stripped-down version of the YGREC16 architecture
yann-guidon-ygdesYann Guidon / YGDES 07/31/2019 at 00:401 Comment
As I received the buttons, I was able to not only get electrical information but also dimensions. I updated the layout:
The 50 buttons easily fit in a 18×18cm square so 20×20cm is a safe dimension for this panel.
Remember that it's only the instruction, and more things are done in other panels :
[deleted]
Yann Guidon / YGDES wrote 07/31/2019 at 10:28 point
I'll have to drill many holes :-D
