Tri-mode TAP
A project log for YGREC8
A byte-wide stripped-down version of the YGREC16 architecture
Yann Guidon / YGDESYann Guidon / YGDES 11/21/2021 at 07:360 Comments
Now that I have an assembler, how do I upload the program into the core ?
The TAP (Test Access Port) allows one to upload data, instruction by instruction, then make the core run them. However this is quite complex and not suitable for autonomous operation, like, when the core works alone.
One thing I would loooove is to hook the circuit to a serial port of my computer and then cat a binary file through /dev/ttyS0 to the circuit. When 512 bytes are transferred, the processor starts the uploaded program. It's convenient from the user's point of view, though it doesn't allow full debugging and requires baud generation circuits. Some sort of external adaptation circuit on a dongle must be designed.
Another interesting situation would be that the TAP circuit itself goes to fetch the program by itself. Usually it comes from a SPI Flash device, and I have already developed such a system in 2014/2015 for #WizYasep.
I am familiar with SPI Flash devices: #SPI Flasher implements a few protocols already. SPI usually works with 4 signals :
Compare this to the TAP interface:
It looks quite similar, right? Furthermore, the TAP contains the shift register and the other circuits that write to the program memory, which is indexed by the PC register (the latter conveniently wraps around to 0 when the upload is over, and signals the FSM to start running said program).
So there are already about one half of the circuits in place for autonomous loading, now the trick is how to hack the existing system to add the new features.
First, the Y8 interface needs to know the operating mode. So far, the TAP had only one mode so the question didn't arise but we have identified 3 modes, that would be conveniently selected by weak pull-up/down resistors on the pins:
  1. TAP mode : R/W low, CLK low (?)
  2. External/slave programming mode : R/W low, CLK high (?)
  3. Autonomous SPI programming mode : R/W high
It starts to look like what modern FPGA provide...
Usually, the R/W pin is pulled up by an internal weak resistor, which is overridden by an external upload/control device. The default behaviour is to get the stream of 4096 bitts from external SPI storage. I'm not sure yet about the CRC/scrambling, which can be designed/added later, but should not remain an afterthought for ever.
The state of the  R/W pin is sampled by the FSM during the Reset sequence, just after the /Reset pin is brought high. Note that the TAP is still functional even when the rest of the chip is held in RESET state, since TAP as its own reset sequence and clock domain.
Note: the TAP used to have 3 pins only (plus external RESET though it could also be controlled from within the TAP registers). See https://hackaday.io/project/27280-ygrec8/log/182563-tap-pins for the diagrams. Now, in addition to the previously defined interface, the external debug/upload device must control the /Reset pin to take over the internal FSM and prevent conflicts with the internal operation. The minimal number of pins for the probe is 6 but more become desired:
It's on the "high tier" of the pin count range for probes but that's the price for sharing a SPI bus between 2 masters. It's also for safety due to the uncertainty of the support of "half-duplex" mode by SPI Flash chips. I added these 2 pins:
I know it's getting more complex but not everything is required in the beginning. Maybe I'll find a trick to remove one of the signals because each pin is a precious resource...
