Register name display : OK
A project log for YGREC8
A byte-wide stripped-down version of the YGREC16 architecture
yann-guidon-ygdesYann Guidon / YGDES 10/24/2019 at 17:450 Comments
Hi dear reader ;-)
Some pictures would probably please your eyes, I hope you enjoy the sight !
It was quite some work but the result is nice. The only gotcha was a forgotten diode/segment in the decoder at NU2.A:
Here is a video of one unit under test :
I reuse the same pinout and test board as the #Numitron Hexadecimal display module for convenience :-)
I'll have to do some "optical design" to prevent glare/reflections and keep the Numitrons readable, but this is for another time. As you see, I use a separate connector for modularity so I can design the front panel independently.
I'm already working on the condition display...
