Getting started with the pocketbeagle
A project log for PORG
yep
davedarkodavedarko 09/28/2017 at 22:313 Comments
https://github.com/beagleboard/pocketbeagle/wiki/FAQ
https://beagleboard.org/pocket
https://octavosystems.com/2017/09/21/pocketbeagle-launch/
http://www.mouser.de/new/beagleboardorg/pocketbeagle/
Sadly 4 PWM pins aren't enough to get all 8-10 servos running, so I need a controller for that anyway, probably keep the arduino for that. Probably don't even need PWM for the servos though. (probably leeds to PCA9685 check #Servo Breakout for WeMos D1 Mini )
Totally neat: USB is on the GPIO headers. comparing that to the Raspberry PI derivates, that's pretty cool.
deʃhipu wrote 09/29/2017 at 08:27 point
You can get PCA9685 breakouts with servo plugs very cheaply — they are larger than my breakout, but you have room.
davedarko wrote 09/29/2017 at 12:35 point
Right, I have one of those boards on R8J4 fof the eye brows but there are next to no capes for the beaglepocket.
deʃhipu wrote 09/29/2017 at 13:33 point
Someone has to design the first one...
