Enclosure prototype 2
A project log for Nixie Tap
Minimal USB powered Nixie display and IoT button
mladenmladen 12/14/2017 at 21:410 Comments
As always, prototypes should be made fast, cheap and disposable, and designed to fix as much mistakes as possible.
The previous prototype was over-dimensioned, and had really loose tolerances. Also, this enclosure was made in 3d printed plastic, which doesn't really do the Nixies justice.
The priority for Prototype 2 version was to try out different materials, and it turned out successfully.
To make sure that the dimensions were right, an ABS plastic version was produced:
Prototype 2 ABS
Attempt was made to smooth things out, but I messed up with liberal use of acetone :(
To make the darn thing in wood, I turned to Alibaba, and found some suppliers.
 The following wood materials were tested: Mahogany, Black Walnut and Wenge.
Mahogany has an interesting texture:
Enclosure Prototype 2 Mahogany
Wenge is dark, and has some remaining holes from machining, which need to be filled (or maybe not):
Enclosure Prototype 2 Wenge
Black Walnut is my favorite, it has a smooth finish:
Enclosure Prototype 2 Walnut
This was my first attempt to deal with wooden enclosures (so far I only worked with metal), and so far, so good.
I let the manufacturers dictate the finish. Mahogany has no finish (might brush this with some mineral oil), while wenge and black walnut have oil based finish.
