Done with breadboard prototyping
A project log for Bionic Yourself V2.0
Project Bionic Yourself (B10N1C) is a small implant for your arm that makes you a bionic-superhero.
txyz.infotxyz.info 09/29/2014 at 03:393 Comments
Last 3 electronic components was tested with whole system.
HTU21D - humidity and high precision temperature sensor in one IC
MMA8451 - Triple-Axis Accelerometer w/ 14-bit ADC
nRF8001 - Bluetooth Low Energy IC with SPI interface
From tomorrow I'm starting PCB design in Eagle. I'm gonna keep you updated about PCB progress as well.
Stryker295 wrote 09/29/2014 at 16:21 point
Why a humidity sensor? Could that act as a hydration sensor, to see how hydrated the body is from the inside? Definitely curious.
txyz.info wrote 09/29/2014 at 20:55 point
Humidity sensor (HTU21D) for safety, if humidity level rises inside enclosure, that means it is time to remove the device.
PointyOintment wrote 10/06/2014 at 04:46 point
Not a biologist, but I imagine that the hydration of the tissue where this will be implanted is regulated by the body, so it would be impossible to measure the whole body's hydration level from there.
