cambadge.X_withpuzzles.zipMPLABX project 1.03 including puzzle source.x-zip-compressed - 1.27 MB - 11/16/2017 at 16:52 |
badgeboot.x.zipBootloader MPLABX project.V1,03. NB older versions have issues with production badges. MPLABX 4.05 (appears to be OK with 4.0x) x-zip-compressed - 840.65 kB - 11/11/2017 at 00:35 |
cambadge.X.zipMPLABX project for badge V1.03 excluding puzzle sources(These will be added after the event.) MPLABX 4.05 (appears to be OK with 4.0x) Use this version as a base, not any previous ones due to hardware issues on production badges. x-zip-compressed - 1.77 MB - 11/10/2017 at 07:42 |
splash.bmpStatic splashscreen included on SD cardBitmap Image File - 48.12 kB - 11/10/2017 at 06:50 |
splash.aviAnimated splashscreen included on SD cardAudio Video Interleave (AVI) - 2.17 MB - 11/10/2017 at 06:50 |
IMAGES.zipSample 128x128 BMP files included on the badge SD cardx-zip-compressed - 798.88 kB - 11/10/2017 at 06:49 |
comp_103.hexComposite hex file including bootloader and application code, for use only with a hardware programmerhex - 728.53 kB - 11/10/2017 at 06:48 |
Badge103.hex.hex for production badge code. Application code only, for loading via bootloader.To program using a hardware programmer, use the comp_103.hex file which includes the bootloader and application code. hex - 414.48 kB - 11/10/2017 at 06:47 |
cardvids.zipsample video files included on SD cardx-zip-compressed - 22.17 MB - 11/09/2017 at 07:40 |
badgeschem.pdfSchematicAdobe Portable Document Format - 100.68 kB - 11/02/2017 at 10:06 |
cambadge2.xyrs.csvMacrofab XYRS (BOM) fileComma-Separated Values - 3.71 kB - 10/22/2017 at 09:54 |
IMG_0363.JPGFirst prototype boardJPEG Image - 394.55 kB - 10/19/2017 at 19:39 |
CAM0004.BMPSample image, x4 zoomBitmap Image File - 13.05 kB - 10/19/2017 at 12:54 |
CAM0003.BMPSample image, mono x2 zoomBitmap Image File - 13.05 kB - 10/19/2017 at 12:54 |
CAM0002.BMPSample image, mono, x1 zoomBitmap Image File - 13.05 kB - 10/19/2017 at 12:54 |
CAM0001.BMPSample image, color, x2 zoomBitmap Image File - 36.05 kB - 10/19/2017 at 12:54 |
CAM0000.BMPSample image, colour, x1 zoomBitmap Image File - 36.05 kB - 10/19/2017 at 12:54 |
avi_mono.AVISample mono AVI file from cameraAudio Video Interleave (AVI) - 276.77 kB - 10/19/2017 at 12:50 |
avi_rgb565.AVISample colour (RGB565) AVI file from cameraAudio Video Interleave (AVI) - 360.59 kB - 10/19/2017 at 12:49 |
cambadge2.DXFDXF of board for mechanical dimensionsAutoCAD DXF - 239.03 kB - 10/17/2017 at 09:10 |
boot101_comp.hexFactory-programmed firmware image. Contains bootloader and application codehex - 728.53 kB - 10/13/2017 at 20:02 |
cambadge2.pcbPCB file for PCAD2006.Should import into Altium Designer or Circuit Studio pcb - 1.37 MB - 10/10/2017 at 22:15 |
CAMBADGE2.GBR.ZIPPCB Gerber files.x-zip-compressed - 325.15 kB - 10/10/2017 at 21:32 |
hadbadge_pcb.pdfPCB layout drawingAdobe Portable Document Format - 105.55 kB - 10/10/2017 at 21:30 |
avi.pdfAVI file format description - original version appears to have disappeared from the internetAdobe Portable Document Format - 208.16 kB - 09/24/2017 at 00:16 |
Simplified Windows BMP Bitmap File Format Specification.htmBMP file format descriptionHyperText Markup Language (HTML) - 27.18 kB - 09/24/2017 at 00:16 |
OV9650_software_application_notes1.03.pdfOV9650 appnotesAdobe Portable Document Format - 507.54 kB - 09/24/2017 at 00:14 |
OV9650impguide.pdfOV9650 implementation guideAdobe Portable Document Format - 1.18 MB - 09/24/2017 at 00:14 |
OV9650-1.pdfOV9650 datasheetAdobe Portable Document Format - 741.24 kB - 09/24/2017 at 00:13 |
SSD1351-Revision+1.3.pdfOLED controller datasheetAdobe Portable Document Format - 1.52 MB - 09/24/2017 at 00:10 |
OLED Module 128x128.pdfOLED Module datasheetAdobe Portable Document Format - 2.01 MB - 09/24/2017 at 00:10 |
