This is going to be easy
A project log for Weight coaster
12 LED ws2812 ring that lights up depending on how much drink is in your glass. It uses a load cell to weight the drink.
facelessloserfacelessloser 09/24/2017 at 10:210 Comments
These are the famous last words, This is what I thought when I first started this project. I got the inspiration from Jeremy S Cook light up coaster. I was planning on using a load cell from bathroom scales but it turned out it was hard to mount them in the way I needed them to be.
I needed to use a HX711 load cell amplifier to feed the arduino
