• 1
    Searching for the right microphone
    I simply took a look on ebay and quickly found  a fitting one for about 2 €. It was not exactly the right one with the ideal footprint but at that time I didn`t know better and so i bought it.
    (This would be the right one: http://www.ebay.de/itm/Mikrofon-Mic-Konnektor-Microphone-Mikrophon-Connector-fur-LG-G3-D850-D855-K-/321622200576?hash=item4ae22d5100:g:ld8AAOSwiCRUlYVM)
    The ideal  spare part for the lower microphone (LG G3 D855) looks like this:
    But you know how things are if there is nothing like a instructable or something else on the internet, you simply have to try out and so did I and bought the wrong one. But hey IT WORKS !!! :D
  • 2
    Opening your LG G3
    The LG G3 itself is quite "maker friendly". You can open it very easy. As allways keep in mind, that working on a pcb with microcontrollers without ESD-protection is very risky and can destroy your device, so be careful. ( I have actually no particular esd mat or bracelet but I'm trying to ground myself before starting and between the processing. BUT for further works I'll definitly buy one, I mean they cost about 25€ and can protect you against damaging your expensive  devices.)
    How to open it is well described in this video:
  • 3
    Finding the microphone on the PCB
    The microphone is located near the micro usb connector. I marked it in the picture below.
