close-circle
1971 Game
1971 is a real-time strategy game that follows the story of Indo-Pakistan war of 1971
close
1971 is a real-time strategy game that follows the story of Indo-Pakistan war of 1971 that led to the formation of Bangladesh. Being one of the shortest historic wars, lasting just 13 days, this game will come up with different levels in the Campaign Mode. A Deathmatch mode will be provided where the user does not follow the campaign but plays against the computer.
Player starts from a basic set-up of armed forces and warfare equipment. As the game progresses, reinforcements arrive to support the player. Maximum population capacity of 10 is there for each player. Player may be asked to ambush the enemy or, defend against infiltration. Player is expected to play intelligently in the game. There are 3 playable unit classes: RIFLEMAN(infantry), HOWITZER(artillery), TANK(cavalry).
Uses C, Keil IDE, LPC2148 (ARM7) Blue-board, LCD display, 2-Axis Joystick, Push buttons, USB A to B Cable, Speakers
Gameplay Algorithm
1. Home screen display.
2. If any pushbutton is pressed, go to Main Menu.
3. There are 4 options in Main Menu: Campaign, Deathmatch, Help, Exit.
4. Options can be selected using up-down joystick functionality.
5. Selected option can be entered by SELECT Key (X-Key).
Campaign Mode
1. This mode has 4 levels.
2. Enter any option using joystick & SELECT Key.
3. After level is selected, a level description is loaded from where Play mode can be invoked.
4. BACK Key (Y-Key) is used to go to Main Menu.
Deathmatch Mode
1. This is a special map where face-off beteen foot soldiers takes place.
2. Play mode can be loaded to start the map.
Help
1. Play instructions are loaded on the display.
2. User can go back to Main Menu by selecting Y-Key.
Exit
1. User is taken back to Home screen.
Play Mode
1. X-Key is used to select different units.
2. Y-Key pauses the game and asks whether the user wants to quit the game.
3. Joystick is used for movement of each unit.
4. The enemy AI is built in such a way so as to detect weakest enemy in range and follow/attack them.
5. The player only need to move the units at correct locations to win the game.
6. The player is free to design effective battle formations with the available units.
7. The level ends whenever a side loses all of its units.
Circuit schematic
Portable Network Graphics (PNG) - 239.90 kB - 11/29/2017 at 09:08
eye
Preview
download-circle
Download
Flowchart part 2
Portable Network Graphics (PNG) - 21.99 kB - 11/29/2017 at 09:05
eye
Preview
download-circle
Download
Flowchart part 4
Portable Network Graphics (PNG) - 32.31 kB - 11/29/2017 at 09:05
eye
Preview
download-circle
Download
Flowchart part 3
Portable Network Graphics (PNG) - 27.08 kB - 11/29/2017 at 09:05
eye
Preview
download-circle
Download
Flowchart part 1
Portable Network Graphics (PNG) - 27.43 kB - 11/29/2017 at 09:05
eye
Preview
download-circle
Download
View all 15 files
  • 1 × LPC2148 Blueboard Microcontroller
  • 2 × Large Push Buttons Input device
  • 30 × Jumper Wires For connections
  • 1 × USB A to B Cable For programming
  • 1 × 9V Power Adapter Power Supply
View all 13 components
  • Progress till 24-11-17
    Sarthi Chugh11/24/2017 at 23:11 0 comments
    Updated unit sprites
    Added sprites for Game Victory and Defeat
    Level-specific unit generation implemented
    Implemented unit attack/follow logic
    Added enemy health bar for enemy strength indication
    Added health-loss animation
    Calibrated Joystick ADC interface
    All game levels are completely functional
    --TODO--
    Fix key debounce issues
    Add menu selection and unit attack sounds
    Testing
  • Progress till 19-11-17
    Sarthi Chugh11/19/2017 at 19:41 0 comments
    Created sprites for game logo and all units
    Created display logic for normal and bold characters
    Implemented different unit description and menu screens
    Implemented unit movement logic
    Implemented buffered-output on LCD display
    Interfaced push-buttons and joystick
    TODO-
    ADC Calibration
    Level specific Unit generation
    Unit attack/follow logic
    Game sounds
  • Progress till 5-11-17
    Sarthi Chugh11/05/2017 at 04:16 0 comments
    Tested multiple EINT push-button triggered interrupts.
    Tested ADC functionality through 2-axis Joystick
    Generated sample sounds through AUX port
    Created Unit-movement and attack logic
    Tested basic functionality in LCD display
    --TODO--
    Create sprites for Units
    Create display logic
    Test display using TFT/VGA
    Calibrate ADC interface
    Create game-progress logic and levels
    Implement unit and game description menu
    Implement save game feature
    Test .wav/RIFF sounds
View all 3 project logs
