The Exoskeleton
A project log for Exercising Exoskeleton
Upper body exoskeleton for exercise in VR.
wbm5wbm5 10/16/2017 at 01:160 Comments
With everything finally designed (at this point) I thought it a good idea to make it available for others. Finding an open source exoskeleton is near impossible, let alone one that has a solution for scapular movement. So look for the link below. (119 MB zip file on GoogleDrive)
The hardware used for the joints are 1/4" nuts with associated bolts. The cables to be used are 0.3mm in diameter and will fit a standard brake sheath from a bowden cable. I also used ball bearings found here.
The assembly of the exoskeleton
