Hackaday.io Hackaday.io
Sign up Log in
Liquid Alarm Clock with Touch Interface
A colorful alarm clock using two LED rings to show the time.
cfCF
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.8k views
3 comments
120 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 3
View Gallery
1.8k
3
120
31
Team (1)
  • cfCF
Join this project's team
MISC
ongoing project
ws2812b clock arduino touch
Related lists
Look at this
Just good looking projects made on Hackaday
This project was created on 09/25/2017 and last updated 8 years ago.
Description
A 15x15cm alarm clock using two LED rings (97 LEDs in total) to show the time. Beside the blue pendulum, there is a point for the hour (green), minute (red) and second (yellow). The alarm-indicator is in the middle. Everything is controled by a touch wheel with a button in the middle, like the first iPods. It's a 12h alarm clock. The brightness can be set by hand or automatically by a photoresistor. There is a night mode, which starts at a certain outer brightness (can be set by the user), where all LEDs are off. There is a optical sensor on top, for a night touch. Whiping your hand above the sensor will start the clock for three seconds at night. There is a possibility to add a Bluetooth modul to control the clock via your smartphone, but it's not implemented in the firmware right now.
Details
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Xasin wrote 07/28/2021 at 15:03 • point
This is quite an old project - perhaps a version could be made using an ESP32 now that they are more readily available!
This could bring in WiFi or Bluetooth right from the start, as well as perhaps a few other features like network synchronized time.
Either way - what a beautiful display. The elegance above all is lovely!
gdm44752 wrote 09/30/2017 at 20:24 • point
Some instructions?
Kenny.Industries wrote 09/26/2017 at 22:23 • point
files for the project would be interesting )
Word Clock is a special type of clock where the current time is highlighted within a set of words that can tell any possible time.
Project Owner Contributor
ESP8266 Word Clock on 16x16 Led Matrix
mircemkmircemk
The 2018 Hackaday Prize
Tix Clock Implemented In a Gem Mine Diorama
Tix Clock Gems
chris-chungChris Chung
A programmable, pixelated WiFi analog+digital clock the size of a credit card
Foxie CardClock
will-fox-foxie-productsWill Fox (Foxie Products)
A nice-looking Analog style ring clock
DIY WS2812 Analog style Arduino Ring Clock
mircemkmircemk
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Liquid Alarm Clock with Touch Interface", please tell us the reason.
Send message
Remove Member
