Getting the numbers
The images are captured with the notebook's camera with OpenCV and then processed to get more clear images for the numbers, then with Tesseract I get the numbers in text format.
Choosing where to slide
Using PyBrain I create a neural network (multilayer perceptron) and balance its weights with a genetic algorithm using PyEvolve.
The input of the network is a matrix with the log2 of each number divided the maximum log2 number, and the maximum number of the output is the direction where we should slide the stylus.
A console-terminal version of 2048 was made for training.
Sliding the stylus pen
To slide the stylus I used a parallel SCARA I made long ago, it uses an arduino to drive the servos.
Here is an image to understand the math behind the code.
