Battery Modules​
A project log for 6S IOT BMS
A BMS that publishes Cell Voltage to a MQTT Broker
johannesJohannes 10/25/2017 at 16:580 Comments
I started designing battery modules which can hold 4x 18650s.
It's just a quick prototype and will be refined in the future, probably making it modular so you can add as many 18650 cells as you like...
They are keyed so there is no possibility to plug them in the wrong way.
