Using Visuino to import already built and coded custom Remotley controlled balancing Arduino robot. Having 6 RC receiver channels, Gyro
First build with Visuino, prepation step tword multi project importation from Arduino IDE to Visuino.
fzz - 71.58 kB - 09/29/2017 at 04:01
ino - 13.62 kB - 09/29/2017 at 04:00
owarduino - 8.80 kB - 09/29/2017 at 04:00
ino - 4.81 kB - 09/29/2017 at 03:59
The Need for testing anything that will come its way, like being thrown to the ground 4 times.
then dropped about 5 times.
Oh, yea and kicked across the room a few good whacks also.
This was fun, and he did surprisingly well, not like those stick figure toothpick balancers.
He lost his cookies on only one item, the right side motor/gear box/wheel, cheap 0.99 cent things.
This is "CUTSIE WHUN - I WANT TO BREAK YOU"
View project log
Jithin Sanal
Mert_Arduino
engineerkid1
Yes, delete it Cancel
You are about to report the project "CUTSIE WHUN and Visuino - balancing 6 RC channels", please tell us the reason.
