CUTSIE WHUN and Visuino - balancing 6 RC channels
Using Visuino to import already built and coded custom Remotley controlled balancing Arduino robot. Having 6 RC receiver channels, Gyro
Using Visuino to import already built and coded custom Remotely controlled balancing Arduino robot. Having 6 RC receiver channels, Gyro A flawless first try at transferring the 450 + lines of code from the CUTSIE WHUN self balancing robot into Visuino.
First build with Visuino, prepation step tword multi project importation from Arduino IDE to Visuino.
CUTSIE_WHUN_V1.fzz
Fritzing BreadBoard
fzz - 71.58 kB - 09/29/2017 at 04:01
Download
CUTSIE_WHUN_V1.ino
The untouched original Arduino IDE code
ino - 13.62 kB - 09/29/2017 at 04:00
Download
CUTSIE_WHUN_V3.owarduino
the build with visuino
owarduino - 8.80 kB - 09/29/2017 at 04:00
Download
CUTSIE_WHUN_V3.ino
The Visuino produced code
ino - 4.81 kB - 09/29/2017 at 03:59
Download
  • CUTSIE WHUN - I Want To Break You
    [SF] Pigeon Kicker -- AkA James Ryan09/29/2017 at 04:19 0 comments
    The Need for testing anything that will come its way, like being thrown to the ground 4 times.
    then dropped about 5 times.
    Oh, yea and kicked across the room a few good whacks also.
    This was fun, and he did surprisingly well, not like those stick figure toothpick balancers.
    He lost his cookies on only one item, the right side motor/gear box/wheel, cheap 0.99 cent things.
    This is "CUTSIE WHUN - I WANT TO BREAK YOU"
View project log
